Activity Forums Maxon Cinema 4D Pc Shutsdown While Rendering…
  • Pc Shutsdown While Rendering…
    Posted by Ray Nyugen on March 7, 2013 at 5:42 pm
    Hey guys! Yesterday night, I tried to render out a small animation(text+camera keyframes)… and in all of the sudden my PC shutdown…
    Does anyone know a solution? It’s probably NOT the heat and dust. Thanks in advance!
    PC specs:
    C4D R12
    Windows 7 64bit
    AMD Phenom II X4 840 3.2 GHz
    8 GB RAM
    ATI Radeon HD 5570
    Ray Nyugen replied 13 years, 5 months ago 2 Members · 4 Replies
  • Ashish Gupta
    March 8, 2013 at 1:17 pm
    Ray,
    Have u tried rendering the same project again ..?
    I dont think it is a problem of C4D .. there can be many reasons that causes shutdown …
    https://www.pcsoftwaresbay.com/fix-pc-problems/20-sudden-computer-shutdown-problems-and-how-to-fix-it.html
  • Ray Nyugen
    March 8, 2013 at 6:08 pm
    Thank you for your reply.
    I have tried to render (export to mp4 OR PSD sequence) it 11 times. Its also first time in 2 years that my PC shutdown… I never had shutdown problems.. till now.. C4D… rendering…
  • Ashish Gupta
    March 9, 2013 at 8:42 am
    May be you should try rendering the project on someone else’s PC ..
    If the same problem happens again than it must be a problem with cinema ..
  • Ray Nyugen
    March 11, 2013 at 11:19 pm
    I have the same problem with Adobe Premier Pro when I try to export/render it out…
    I guess my PC cant handle it ?_? (even the req are O.K)
