Activity Forums Adobe After Effects PC for AE
  • Posted by Forhadul Islam on September 18, 2018 at 5:45 am
    Generally, I use:
    – Adobe After Effect
    – Premiere Pro
    – Adobe Audition
    – Photoshop
    – Illustrator
    – C4D
    I have planned to make a Desktop PC.
    Here I have found out the configuration:
    Processors Intel Core i9-7900X X-series Processor
    Ram G.Skill Trident Z 16GB DDR4 3200 RGB
    Motherboard ASUS TUF X299 MARK 1
    SSD Transcend SSD220S 2.5″ SSD SATA III 6Gb/s Internal 480GB SSD
    Casing Cooler Master Masterbox 5 MSi Edition Mid Tower Chassis
    PSU Cooler Master PSU Gold V1000 Full Modular
    Cooling System Thermaltake Water 3.0 Riing RGB 360/All-In-One Liquid Cooling System/Riing RGB 120*3
    GPU 1080ti (I have)
    Could you please suggest me this will be fine for my work?
    Budget $3000 (without GPU)
    ……….:::F♥rhad:::……….
    Forhadul Islam replied 8 years ago 2 Members · 2 Replies
  • Walter Soyka
    September 18, 2018 at 12:42 pm
    I’d generally spec 32 or 64 GB of RAM for an After Effects machine. I would also consider more storage; perhaps an M.2 or second SSD drive. You can always add both of these components later if you need to.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Forhadul Islam
    September 18, 2018 at 2:21 pm
    Hi Walter,
    Thank you so much for your reply. Could you please tell me without this 2 thing another component is perfect for my work? Will I get the good performance from this machine?
