Activity › Forums › Adobe After Effects › PC configuration for CS3
Posted by John Vanaman on October 4, 2007 at 2:07 amOk so here are my specs. The question is, will this PC have enough oompfff to run The CS3 production bundle and Windows Vista together
SPECS ON MY MACHINE:
Windows Vista Premium
HP Media Center PC m1180n
NVIDIA GeForce 7300 GS (graphics card dual monitors)
550 Duo processor Intel Pentium 4 3.40GHz with hyperthreading.
3 Gig RAM
Thanks.
J
Steve Roberts replied 18 years, 11 months ago 4 Members · 6 Replies -
Brendan Coots
October 4, 2007 at 4:36 amFirst of all that processor is NOT dual core. Hyper-threading is just a little trick that allows multiple apps to access the CPU at once, but it is not (and will never match the performance of) a true dual-core processor.
Second, I would step up to a true dual core machine. This HP model is very outdated (2004, almost an eternity in computer time) and you could get much better for fairly cheap. That amount of RAM and the video card are fine, but the computer itself is a bit dated.
Steve Roberts
October 4, 2007 at 12:02 pm… and try to get XP Pro. Reports indicate that if you have the choice, avoid Vista for professional graphic apps.
John Vanaman
October 4, 2007 at 1:21 pmThanks! Great info
I work at a university and can get PC’s at great prices, but they use Dell as their provider. Any thoughts on Dell machines for this kind of work?
J
Kevin Camp
October 4, 2007 at 1:47 pmdell used to make some pretty good higher end machines several years ago…. but i haven’t kept up much with the latest pc developments, i’ve been in a mac shop for several years now… although i’ve read great things about their more recent high end displays.
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Brendan Coots
October 4, 2007 at 5:56 pmMy studio uses Dell displays exclusively, even on our macs, just because they are so nice and much cheaper than Apple’s displays.
As for workstations, they have some decent options. My only gripe is that they use cheap components, and support is a joke. In general, I would recommend going for the Inspiron 530 or better (ideally an XPS 410 or better), if you can afford it.
Steve Roberts
October 5, 2007 at 2:17 pmFrom what I’ve heard, Dell’s consumer support is not good, but I’ve found that their business support is great.
Two-tier? Yes.… but if you buy a business system as a business, you should be golden.
