Activity › Forums › Panasonic Cameras › PC card slot on 17″ Powerbook
Posted by Peter Carroll on March 18, 2006 at 3:26 pmI have a 17″ 1.5GHz Powerbook G4. This computer will soon be loaded with Final Cut 5.0.4. Will the PC slot on this Powerbook accept and be able to read p2 cards in Final Cut?
many thanks.
Mike Schrengohst replied 20 years, 6 months ago 5 Members · 9 Replies -
David Garcia
March 18, 2006 at 4:57 pmYup. Got one in mine right now. Works good.
david garcia
Halflife* Digital
albuquerque, nm -
Mike Schrengohst
March 18, 2006 at 11:40 pmYes it does work. But check you levels on output.
I am having a bug where the imported P2 files
converted to QT look at little lighter than the original P2.
It’s hard to really tell what you are shooting. -
Mike Schrengohst
March 19, 2006 at 5:32 amSomeone said not to rely on the S-vid signal coming out of the camera.
Maybe I am comparing Apples to Oranges. Maybe the component signal is a more accurate guage, I will try that tomorrow. -
Jeremy Garchow
March 20, 2006 at 7:40 pmThere’s your problem. If you were looking at a waveform, then we could have this duscussion. Since you are looking through two different sources (S-video/componenet), it’s hard to say. Your S-video is probabaly adding setup to your image, while the componenet might not be which account for a shift in the picture.
Jeremy
David Garcia
March 20, 2006 at 9:57 pmI ran a quick test on this (it’s in the thread above) and it’s ddefinitely not hte P2.
david garcia
Halflife* Digital
albuquerque, nm
