Activity › Forums › Adobe After Effects › PC-Based Parse Error
  • PC-Based Parse Error
    Posted by Mikhail Shraga on February 11, 2008 at 8:56 am
    Hello.
    I am running AE CS3 on Win. Vista.
    I have encountered one of those issues where AE crashes and then won’t start again, displaying instead a message that reads
    “Error Parsing Properties List”
    Now i’ve seen other posts on here about this but please keep in mind that i am using a PC.
    I would appreciate any advice on how to fix this and prevent it from happening again.
    I have tried to reinstall AE but the problem persists.
    please help.
    Todd Kopriva replied 17 years, 7 months ago 3 Members · 3 Replies
  • Mikhail Shraga
    February 13, 2008 at 1:04 pm
    Actually here’s the solution:
    (I’m running Vista so this would be a little different on XP.)
    All you have to do is delete the contents of
    C:\Users\*User*\AppData\Roaming\Adobe\After Effects\8.0
    and then run AE.
  • Matt White
    April 9, 2008 at 8:34 pm
    Sorry I know this has been posted, but there is a little confusion.
    If you are getting the error “parsing list”
    First try right clicking on After Effects and run as administrater.
    If that does not work go to
    C: Users / *Main Username* / AppData / Roaming / Adobe
    In the Adobe folder delete the After Effects folder. It will run then. Also make note that the AppData folder might be hidden.
  • Todd Kopriva
    February 13, 2009 at 4:08 pm
    There’s some more detail about one potential cause of this error on my blog:
    crash on start with error parsing properties list
    If you delete one of the XML files in this directory (the directory that contains the preferences file) at a time, then you can avoid needlessly throwing away such useful things as saved workspaces.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
