Activity › Forums › VEGAS Pro › Pausing Templates!
  • Pausing Templates!
    Posted by Simon Law on August 21, 2014 at 11:24 pm
    Hi guys!
    I’m new to this forum. I need some help quick. This video project is due very soon, and I am very lost. I’ve been asked by my church leaders to make a video for the church’s 25th anniversary, so I got Sony Vegas Pro 12 to do it. I’ve gotten a template, which is exactly what I wanted. You see, I want to put a bunch of videos (interviews of church members) that I’ve recorded at church into the template. The template, simply put, is a bunch of rectangles flying around, zooming into each one separately for about 2-3 seconds each. The thing is, the interviews are all over 1 minute each, some for over 4 minutes. So the question is, how do I let the template zoom into one of the rectangles, then I pause it, let the video run, and let the template move onto the next rectangle, and so on?
    Thank you guys so much! Your help is greatly appreciated!
    Stephen Mann replied 12 years, 1 month ago 4 Members · 15 Replies
  • 15 Replies
  • Steve Rhoden
    August 22, 2014 at 4:16 am
    You can easily use the Velocity Envelope to achieve this.
    I am pressed for time, so do some quick read up on this feature
    and some tutorials online, and you’ll be done in no time.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Simon Law
    August 22, 2014 at 1:52 pm
    Thank you so much for your help! But I’ve had no luck trying this out. I’ve tried Velocity Envelope as well as Transition Envelope. I can’t seem to do anything. The transition envelope is even grayed out, so I can’t use that. I’m guessing the template has no transitions? (I’m making stuff up.) The video continues flying around to the next rectangle after 2-3 seconds. Changing the velocity has no effects either. Nothing changes when I change the velocity to 300% or -100%. Help!
  • Graham Bernard
    August 22, 2014 at 7:18 pm
    O…K…
    I’d need to see ScreenGrabs of your Timeline AND the look/appearance of these “Templates”.
    This is where a text-based means of communications in attempting to assist one of our Vegas colleagues falls over . . . Visuals I need visual clues to what you are doing.
    G
  • Simon Law
    August 22, 2014 at 7:52 pm
    Thank you for replying!
    This is the template I’m using: https://www.youtube.com/watch?v=XidjoOQG6q4
    At the 0:10 mark is where I want to insert one of my interviews.
    I want to let the rectangle come towards the screen, then stop the template, let the video run, then move onto the next rectangle and so on.
    I hope this clarifies things!
  • Graham Bernard
    August 22, 2014 at 8:01 pm
    Need to see your Timeline with all those tracks on? I don’t think we are singing from the same Hymn Sheet?
    Where did you get this tremplate/download it from?
    Need the facts – man . . need the facts!
    Grazie
  • Simon Law
    August 22, 2014 at 8:12 pm
  • Graham Bernard
    August 22, 2014 at 8:56 pm
    Righto . . . .
    Somewhere amongst ALL those 25 Tracks is/are the Control KeyFrame/s for the Track Motion. Is this the “Motion” you want to pause? Are you wanting to PAUSE the movement of the the position of the Video. I believe Steve was thinking that you were only wanting to PAUSE the the ACTION within the Frame – hence the Velocity Envelope. Or, are you wanting to HOLD or PAUSE the movement of the Frame in 3D space?
    So, we’re needing to confirm with you:
    A] Frame Motion in 3D space
    or
    B] The motion within the Frame
    or
    C] Both A] & B]
    Need to clarify.
    Grazie
  • Simon Law
    August 22, 2014 at 9:11 pm
    Ah, that’s why Steve told me about the Velocity Envelope.
    I want the rectangle (frame) to stop, but the video within the rectangle to play.
    So choice A.
  • Graham Bernard
    August 22, 2014 at 9:26 pm
    Yeah, I thought as much . . .
    OK, you’re going to need to get BUSY with the Track Motion Keyframes, and move them further apart to SUSTAIN their actual position in 3D space. Do you know how to do this?
    Grazie
  • Simon Law
    August 22, 2014 at 9:32 pm
    I’m very new to Vegas Pro 12. No, I don’t. Help me please. :c
