you won’t be able to have compA stop playing but still have any nested comps within compA keep playing….
you’ll need to go into compA and use time remapping to make what ever parts need to freeze, freeze, leaving all other nested comps/elements alone, or you’ll need to remove all the nested comps and other elements from compA that you don’t want to have freeze, bring them all back into a new comp and then just freeze compA.
essentially all the elements that you want to freeze will need to be in the same comp, any elements that you don’t want to freeze will need to be separate from the freeze comp (either as separate layers or a separate comp). if you don’t have too many layers that you want to freeze, then you might be able to just freeze those elements individually, but it will most likely be easier to have them in a single comp and use time remapping on that comp.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
