Activity Forums Adobe Illustrator patterns, drop shadows, and dashed lines- preparing for print
  • patterns, drop shadows, and dashed lines- preparing for print
    Posted by Shannon Conahan on March 30, 2012 at 1:57 pm
    hi guys, i have a flyer i just created that uses a few things that im not sure how to prepare for print:
    1. a pattern: my base layer is one rectangle with a solid color and a pattern. do i have to do anything special to the pattern or will it be safe during print?
    2. drop shadows: another rectangle in my picture has a drop shadow on it. i also have some text with stroke and drop shadow. i only know how to outline the font and the stroke in a text…but ive never outlined a drop shadow on anything before. do i have to do this and if so how? (both for the text and the rectangle’s shadow)
    3. dashed lines: one of my rectangles has a stroke that i made into dashed lines…but i think i managed to outline all of those. i selected only this rectangle, and then hit object>flatten transparency, with “convert strokes to outlines” checked. so i think that ones safe now…just wanted maybe another opinion on this if you have it!
    so basically, the first 2 points are my main concerns. any ideas or suggestions? im searching all over the web but cant find the answers im looking for.
    any help would be a life saver right now as ive gotta send this out to the printer asap. thanks so much!!
    -shannon
    shannon
    Vincent Rosati replied 14 years, 5 months ago 2 Members · 1 Reply
  • Vincent Rosati
    April 1, 2012 at 7:52 pm
    The only thing that concerns me in your post is the drop-shadow. Transparency effects can be the cause of a number of issues.
    Ultimately, you just need to do a test print and see how it looks.
    Save a PDF with embedded fonts, or as a TIF with LZW compression.
    Just some initial thoughts.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
