Activity Forums Maxon Cinema 4D pattern for a model
  • pattern for a model
    Posted by Bahare on May 15, 2006 at 8:09 pm
    hello out there,
    I’m architect and modelling a organic form. I would like to print out something like an pattern to be able to build a physical model of my form. is it possible to put a mesh over the form and create a unfolded map of the object?
    thanks,
    b.
    Daniel Moore replied 20 years, 4 months ago 4 Members · 3 Replies
  • Mylenium
    May 16, 2006 at 5:16 pm
    [bahare] “hello out there,
    thanks,
    b.”
    In theory yes, in practice your chances aren’t that good. Your best bet is to create several planar UV maps for all axes and merge them into one, but it requires Bodypaint and is still prone to distortions. You could then use this UV map as a template or bake your rendered data to it. another variant might be setting up several orthographic cameras and render out your scene from different views. Those images could then be put together in photoshop or other programs.
    Mylenium
    [Pour Myl
  • Greg Serafin
    May 19, 2006 at 3:32 am
    On the cheap side, try RHINO – will do withe extreme accuracy.
    IQ
  • Daniel Moore
    May 23, 2006 at 10:16 pm
    You could do it for free with Pepakura Designer. Lots of fun, if your into that sort of thing… : )
