Activity Forums Adobe Photoshop Paths with Magic Wand tool?
  • Paths with Magic Wand tool?
    Posted by Kyle Sowden on August 7, 2011 at 12:09 am
    So i’m trying to make a 3d image from a 3d image using C4D, and to do that I need to export the work path from Photoshop.
    To get the best look, I want to use the magic pen tool. But how do I save the path that the magic wand tool creates? The Pen tool saves it to the ‘paths window’ automatically?
    Weston Selleck replied 15 years, 1 month ago 3 Members · 2 Replies
  • Scott Roberts
    August 8, 2011 at 11:12 pm
    In the Path Palette flyout menu – select “Make Work Path” then set your path tolerance (i usually set it to .5)
    LittleBlackBird.net
    GraphicsDump.com
  • Weston Selleck
    August 17, 2011 at 7:26 am
    After making your selection, go into the paths panel and on the bottom there is a button, I can’t remember exactly what it looks like, but when you hover over it it should say something like “Make Work Path” just click that.
    -Weston
