Activity Forums Adobe Illustrator pathfinder tool
  • pathfinder tool
    Posted by Scott Gaskin on September 21, 2011 at 9:15 pm
    I am trying to make a cut in a circle within Ai. An example in what i’m trying to achieve is shown in the attached image (Top image). I have created 2 small white rectangles that you can see in the top image and placed them over the circle and used the pathfinder subtract tool thinking this would achieve the desired effect but instead get the effect shown in the bottom image where everything is joined.
    I want the cut to give a completely straight edge as shown and found this difficult with the scissor tool.
    can anyone please help?
    Thanks Scott
    Scott Gaskin replied 14 years, 11 months ago 2 Members · 2 Replies
  • Vincent Rosati
    September 21, 2011 at 9:35 pm
    I’m guessing that the circle is a stroked path.
    First, I’d Object/Path/Outline Stroke, or Object/Expand.
    Then perform the Pathfinder operation.
    Or, if you need to keep the stroke, you could apply a clipping mask.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Scott Gaskin
    September 22, 2011 at 8:02 am
    Thanks for your help Vincent. Job done! There’s still lots to learn with this program! Appreciated
    Scott
