Activity Forums Adobe Illustrator Pathfinder Problem
  • Pathfinder Problem
    Posted by Derek Polson on April 23, 2017 at 2:42 pm
    Hi, I usually use the pathfinder to combine objects to a single vector for laser cutting as in Object – Group. Effect – Pathfinder – Add. Object – Expand Appearance.
    This has worked for me upto now but it has always been adding a shape to the outside of another shape then combining them.
    I want to add a shape to the inside of another shape and then combine them but when I try this the shape inside the other shape disappears.
    Any help would be much appreciated.
    Derek
    Vincent Rosati replied 9 years, 4 months ago 2 Members · 1 Reply
  • Vincent Rosati
    May 17, 2017 at 3:23 pm
    Not sure I’m clear on the issue.
    It sounds like you want a compound path, like the letter ‘O’, as opposed to a single path, like an ‘I’.
    You could use – Object > Compound Path > Make.
    Or, if the inner object is under the outer object – Pathfinder > Minus Back.
    Pathfinder > Exclude.
    You may need to use Object > Arrange > … to get the objects in the the proper layering order.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
