Activity › Forums › Boris FX Particle Illusion › Path with Particle Illusion
  • Aharon Rabinowitz
    December 6, 2005 at 3:39 am
    The particles cannot follow a path. Once they are released from the emitter, the move about freely, and can only be indirectly controlled through forces and defelctors.
    Emitters (The thing that emits particles can follow a path you create in pIllusion (by setting up position keyframes), by importing a motion path from After Effects clipboard, or by importing a tab delimited text file generated via one of the plug-ins found at wondertouch’s website – usually a 3D programe exporting position keyframes through a plug-in).
    In short (sorry for all of that) neither the particles nor the emitter can follow a vector path (such as an illustrator path) at this time.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
