Activity Forums Adobe After Effects Expressions Path property Expression to offset the path
  • Path property Expression to offset the path
    Posted by Dániel Ország on January 14, 2024 at 7:23 pm
    So i have this expression for thePathproperty in aShape Group.
    // Get the path from the Shape layer in the composition
    var shapeLayer = thisComp.layer(“Shape Layer Name”);
    var shapeGroup = shapeLayer.content(“Shape Group Name”);
    var path = shapeGroup.content(“Path Name”).path;
    // Get path properties
    var pts = path.points();
    var inTans = path.inTangents();
    var outTans = path.outTangents();
    var closed = path.isClosed();
    // Move the path vertices 500 pixels to the right
    for (var i = 0; i < pts.length; i++) {
    pts[i][0] += 500; // Add 500 to the x-coordinate
    // Create a new path with modified vertices
    createPath(pts, inTans, outTans, closed);
    It moves the path 500 pixel to the right. Only the path itself without touching the transform controls (postion etc..)
    My issue is that i have to manually type the Shape Layer, Shape Group and Path name to make it work.
    I can’t figure it out how to make this expression work in a way to automatically recognise this hierarchy within the Shape Layer.
    its something like ADBE Root Vectors Group, ADBE Vectors Group, ADBE Vector Shape.
    Can anyone help? thx
    Dániel Ország replied 2 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
