Activity Forums Adobe After Effects Expressions Path progress on specific point
  • Path progress on specific point
    Posted by Jakob Wagner on May 29, 2018 at 11:35 am
    Hi all
    With this expression I can set anothers layers position to be exactly half way on a path.
    var pathLayer = thisComp.layer(“Shape Layer 1”);
    var progress = 0.5;
    var pathToTrace = pathLayer(“ADBE Root Vectors Group”)(1)(“ADBE Vectors Group”)(1)(“ADBE Vector Shape”);
    pathLayer.toComp(pathToTrace.pointOnPath(progress));
    My question is; is there a way to get the progress for specific Point (anchor/vertex) on the path. Say the path is made out of five points, can I somehow get the exact progress for the second point? Pretty sure this isn’t posible with the default expressions, but I thought some one in here might had found a clever way to do it.
    Did that make sense? If not please ask.
    Jakob
    Jakob Wagner replied 8 years, 3 months ago 4 Members · 4 Replies
  • Dan Ebberts
    May 29, 2018 at 1:21 pm
    I don’t know of an easy solution for this. I think you’d have to use some kind of iterative solution. I don’t have the code for one, but I’d love to see it.
    Dan
  • Alex Printz
    May 29, 2018 at 1:43 pm
    Try this:
    pathLayer.points(time)[1]
    you might need to do a comp/world conversion conversion.
    -Alex
  • Kalleheikki Kannisto
    May 31, 2018 at 5:08 pm
    I wonder if it is possible to copy just one segment of a path to another path, say the path between points two and three, wherein it would be progress 0-1 between those point of the original path. Not sure if it is possible or even applicable for your needs, but it’s a thought.
    If it works, you would have the secondary path take on the first, then second, then third then fourth segment of the original path and progress 0-1 through each. Although traveling speed would change depending on segment length, so that wouldn’t be much good if you need even progress…
    Senior Graphic Designer
  • Jakob Wagner
    June 1, 2018 at 3:48 pm
    I like the way you think creative about it. It’s a good Idea, which could work in some cases. Unfortunatly not in mine. But thanks!
