Activity › Forums › Adobe After Effects Expressions › Path in 3D
Path in 3D
Posted by Axel Rogge on March 17, 2006 at 8:01 amHi everybody,
is there a hack to move a vertex of a path in 3D by describing it
Pshpsh replied 20 years, 6 months ago 6 Members · 5 Replies -
Mylenium
March 17, 2006 at 10:47 amI have no idea what you are talking about. Sure position can be affected and controled with expressions, but what exactly are you trying to achieve?
Mylenium
[Pour Myl
Steve Roberts
March 17, 2006 at 1:19 pmI think Axel wants a mask to exist in 3D, not constrained to the plane of the solid on which it lies.
Sorry Axel, you can’t do that. A mask, whether open or closed, can only lie on the plane of the flat solid on which it lies.
To make a path which does not lie in one flat plane, you need to actually move an object through three dimensions. However, that path cannot be used to create a stroke, if that’s what you want.
You might want to look into Trapcode’s 3D stroke. However, it too has its limitations which can only be overcome by using a real 3D app.
Does that make sense?
Adolfo Rozenfeld
March 17, 2006 at 7:34 pmI agree with Steve. Plus, if it’s useful as encouragement, it could be good saying that animating strokes in 3D space in a 3D application (like Cinema 4D) is so much easier than one fears before getting into it!
Just in case he means a motion path, sure… the motion paths nodes are just a spatial representation of position keyframes, which of course have 3D position coordinates. The b
Steross
March 18, 2006 at 1:13 pmHi Adolfo
I’m just starting out with cinema 4d to use with my AE projects. I’m having trouble finding tutorials on animated strokes in cinema 4d and my fears are not yet at rest. Could you (or anyone else) point me in the direction of an article on this sort of thing?
Thankyou
Stephen Ross
Pshpsh
March 18, 2006 at 3:55 pmTo make an animated stroke thing in C4D, you can just use “sweep nurbs” on two splines and animate the growth property. Here’s a little tutorial about that
https://www.studiodaily.com/studiomonthly/tutorials/trainup/5192.html
