Activity Forums Adobe After Effects Path Import
  • Path Import
    Posted by Jeffrey Mantlo on April 6, 2008 at 4:37 pm
    Hi there.
    I have 2 questions for both Illustrator and After Effects…
    I came across a video where someone used a used a path (made in Illustrator) to make a 3D Stroke run around the outline of his text.
    My first question is…
    How do you make a path (in Illustrator CS3) like the one in this picture?
    And also…
    How do i import the path into After Effects after iv made it?
    Ian Corey replied 18 years, 4 months ago 3 Members · 2 Replies
  • Mike Clasby
    April 6, 2008 at 10:36 pm
    1) With the Pen Tool?
    2) Copy, Paste… but this from the Help files:
    “To make the data copied from Illustrator compatible with After Effects, the AICB option must be selected in the Files & Clipboard section of the Adobe Illustrator Preferences dialog box.”
    Or just import the Text/Graphic from AI, with it alpha, then in AE when its been dropped into a layer:
    Layer>Auto Trace (set Tolerance and Threshold to 1)
    or if it is just Text, Import it then:
    Layer>Create Outlines
  • Ian Corey
    April 7, 2008 at 1:47 pm
    Command + Shift + O while your text is selected will trace it.
