Activity Forums Maxon Cinema 4D Path deformer texture problem
  • Path deformer texture problem
    Posted by Marco De stefanis on June 5, 2009 at 4:14 pm
    I have a barbed wire moving along a spline with path deformer. However the texture does not follow the object. I tried different texure mapping. I tried to animate the path deformer offset and alternatively the object coordinate along the z axis. But the texture does not follow properly the movement of the object.
    Any clue?
    Marco De stefanis replied 17 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    June 5, 2009 at 10:50 pm
    Stick Texture tag?
  • Marco De stefanis
    June 6, 2009 at 12:10 am
    Thnx Brian,
    The stick texture tag worked fine. I had some trouble at the beginning because I tried to apply it to the null object that contains all the elements of my barbed wire object. But when I made all single components editable, applied the texture to each one of them and the stick texture tag, it went fine.
