Activity › Forums › Avid Media Composer › patching 3/4″ tape to Avid for capture
Posted by Pieter Viljoen on August 20, 2013 at 4:50 pmI’m in that generation of assistants/editors that’s coming up post tape… I need to capture a lot of 3/4″ and was wondering if there’s a basic guide someone can point me to? The capturing process itself I’ve studied from two different books but the patching I’m not entirely sure where to start, because I may need to go looking for cables that we don’t have anymore.
This will be into Avid 6.5 on a 2012 Mac Pro.
Thanks guys
David Gray replied 10 years, 7 months ago 9 Members · 23 Replies -
Shane Ross
August 20, 2013 at 5:28 pmAnd what capture card do you have for this? Mojo? Nitris? Third party?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Shane Ross
August 20, 2013 at 5:34 pmIs it a MOJO DX? older one? The 3/4″ Decks have composite and component outputs. Newer MOJO cards only have SDI…so there’s no compatibility there. But the OLDER Mojo’s that did have this connectivity…don’t work with MC6. Does yours have Component inputs? Heck, does the DECK? Some don’t.
You’ll also need a deck control cable…not sure if the umatic has RS-422, or if you’ll need an adapter. Shoot, why is the deck here up in the attic?
Shane
Little Frog Post
Pieter Viljoen
August 20, 2013 at 5:36 pmI am not at that office right now but it must be at least 8 years old and there are legacy versions of MC if I can’t do it in 6. I will find out and get back to you. Thanks for your help
Shane Ross
August 20, 2013 at 5:37 pmAnd I’ll try to get to that deck to see what it has.
Shane
Little Frog Post
Bill Stephan
August 20, 2013 at 10:44 pmNo component outs on 3/4″ VTRs. Those are strictly a composite-only format.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City -
Mark Raudonis
August 21, 2013 at 3:16 am[Bill Stephan] “Those are strictly a composite-only format.”
Not exactly true, sir!
Most 3/4″ decks had what was called a “dub” cable. Here’s an example of one:
https://www.davidriddle.com/sony7pin.htmlThis output separated the “Y/C” signals… creating essentially a component signal. NOT exactly
what we now know as a”component” recording, but close.So… if you want the best possible signal from a 3/4 ” deck, use the dub cable output through a TBC (Time Base Correctors for you young uns) . Some TBC’s actually had “dub” input connectors.
Good luck!
Bob Zelin
August 21, 2013 at 11:56 amGrandpa here – this is what you will need.
There are two versions of AVID Mojo – the original one with RCA and S-Video connectors, and the newer Mojo DX with SDI connectors.
Your 3/4″ VTR may be one of two varities. The “pro” models, which DO NOT have a Time Base Corrector built into them, and the “broadcast” models that DO have a TBC built into them. Let me assure you that you will not have success (even with the right cables) if you do not have a TBC or Frame Sync on your 3/4″ VTR.
The Sony VO-900, 920 and 950 had built in Time Base correctors (with an option board in them). The older Sony VO 5000, 5020, 5800, 5850 did not have a TBC, and will require a FRAME SYNCHRONIZER (like a DataVideo or Hotronics). The original Broadcast 3/4″ VTR’s from Sony (the BVU-800, 820) required external Time Base correctors.
Your 3/4″ VTR (without a TBC) is producing a heterodyned output – the direct output has an unstable sync signal, and it’s composite output is too unstable to get recorded by an AVID Mojo (or any third party card with a composite video input). The VTR must have a Time Base Corrector or a Frame Sync, and the output of the TBC or Frame Sync is what goes into the composite video input of the Mojo, not the 3/4″ VTR.
SO – you are saying “well, I don’t have a TBC or Frame Sync, and I don’t have a BVU900, 920 or 950 with internal TBC, so let me see what happens when I just plug it into the Mojo” – this is what will happen. You will get a very shakey, or scrambled signal, because the Mojo input circuit can’t lock to the unstable sync signal on the composite video signal. Just like a VHS machine.
IF you don’t have the right toys, you can’t play.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
maxavid@cfl.rr.com -
Neil Hurwitz
August 21, 2013 at 4:31 pmGrandpa Bob is correct
No TBC No Joy
I beleive DPS had a unit that did just this
Un TBC’d analog composite to TBC’d SDI
Hunt around on ebay and you should be able to buy one for under
200.00 If not call MCCOM they got a house full of old
analog gear just waiting for a situation like yours.
From
Another Old GrandPa
who used to torture Bob with 5800’s and Quadra 950’s -
Pieter Viljoen
August 21, 2013 at 5:17 pmthank you, all of you. I try to be humble about whatever knowledge I have but there’s nothing like asking a question like this to remind you just how humble you should be.
I’ll report back with what hardware I have.
