Activity Forums Apple Final Cut Pro Legacy pasting text attributes
  • pasting text attributes
    Posted by Pip Clews on June 14, 2006 at 5:59 pm
    I’m have a large section of text – captioning – that I want to alter to match another sequence. I am trying to change qualities, like origin, font size, justification of text, etc. Is there a way to do this to multiple text clips on the sequence at once? I used “paste attributes,” but it doesn’t seem to include text styles or anything else useful from the text window. Any thoughts? Thanks!
    Ruth Schell replied 18 years, 2 months ago 5 Members · 4 Replies
  • Scott Simmons
    June 14, 2006 at 7:29 pm
    I don’t think there is an easy was to do this. You could format a piece of text then add the correct text (maybe by copy and pasting from somewhere you’ve already typed it) each time and reedit it into the sequence… but I don’t think there’s an easy and quick was like pasting attributes.
    Life is linear. Edit life.
  • Arnie Schlissel
    June 14, 2006 at 11:00 pm
    Take a look at Traffic from https://www.xmedit.com/
    Arnie
    https://www.arniepix.com
  • Kevin Monahan
    June 14, 2006 at 11:48 pm
    You’d use Motion with the AutoMotion plug from Digital Heaven to do that.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Ruth Schell
    July 20, 2008 at 8:49 pm
    In order not to select settings every time I type a subtitle, I’ve superimpose the same subtitle and change the text. It works EXCEPT:
    when I save it in the subtitle Bin in the browser, all the other subtitles in the Bin instantly take on the same Name.
    Any suggestion how to save the new subtitle?
    Thank you.
