Activity Forums Adobe After Effects Pasting Photoshop Paths to AE
  • Pasting Photoshop Paths to AE
    Posted by Dan O’brien on February 28, 2007 at 5:37 pm
    I’m having trouble pasting some shape paths from photoshop into AE 7. I’m selecting the path, copying, but it won’t paste into AE. I’ve tried pasting onto solids, adjustments, but the ‘paste’ command isn’t even available. Any special steps I’m overlooking?
    Dan
    Erik Waluska replied 17 years, 11 months ago 5 Members · 4 Replies
  • Kevin Camp
    February 28, 2007 at 5:45 pm
    i have no problem cutting and pasting paths (from a path layer) or shapes (from a shape layer) from ps cs2 into ae7 (in to a solid)… are you using the path selection tool to select in ps?
  • Simon Robbrecht
    February 28, 2007 at 6:18 pm
    I don’t know whether this works for Photoshop but I know you have to setup a preference in Illustrator to paste paths into the clipboard.
    In Illustrator you have to change this settings in preferences > clipboard > select AICB
    Dunno whether there is something similar in Photoshop.
  • Victor Nash
    February 28, 2007 at 6:30 pm
    Forgive the elementary response, but did you hightlight the position value of your object and Paste?
  • Erik Waluska
    September 22, 2008 at 5:52 pm
    I was having the same problem as Dan. I couldn’t copy and paste a path from Photoshop no matter what I did. I ended up restarting the applications and then the path copied like it was supposed to. Must be a little bug in the apps or something.
    -E
