Activity › Forums › Adobe After Effects › Pasting keyframe problem
  • Pasting keyframe problem
    Posted by Jason Mckee on April 14, 2009 at 2:55 am
    I just tracked my footage in Mocha AE and when I go back to After effects it will only paste every 10th keyframe in. i tracked every frame and have done this a million times but for some reason this is happening. thanks in advance.
    -jm
    Curious Turtle replied 17 years, 5 months ago 2 Members · 1 Reply
  • Curious Turtle
    April 14, 2009 at 6:36 am
    Couple of things for you to check.
    i) Does the data look good in the txt file? That’s to say, is it displaying a keyframe for every frame?
    ii) Does your framerate match between the tracking data and your After Effects comp?
    If both of those are OK, then you should just restart After Effects and repaste the data in. Any time there’s a problem with pasting stuff into AE, a restart is a good cure-all.
    Hope that helps,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
    Just out: Rock Steady : Successful Motion Tracking in Mocha & After Effects
