Activity Forums VEGAS Pro Pasting Event Attributes
  • Pasting Event Attributes
    Posted by Steven Dumala on February 29, 2008 at 2:59 am
    I will apply effects and color correction to a clip and then right click copy that clip. I will then click on the other clip that I want the effects applied to, I will then choose Apply event Attributes.
    I was wondering what gets applied when that is chosen.
    Is there a way to only apply certain effects or attributes when choosing the Apply Attributes?
    Edward Troxel replied 18 years, 6 months ago 2 Members · 3 Replies
  • Edward Troxel
    February 29, 2008 at 3:13 am
    [Steven Dumala] “Is there a way to only apply certain effects or attributes when choosing the Apply Attributes?”
    No. It’s all or nothing.
    Edward Troxel
    JETDV Scripts
  • Steven Dumala
    February 29, 2008 at 5:12 am
    What effects or”attributes” are being applied?
    I have done it before and have had the clip change speed or not be the same start and end of the clip that i had used.
  • Edward Troxel
    February 29, 2008 at 1:26 pm
    The “in” point shouldn’t change but the “out” point could if you’ve changed the speed on the original clip. According to Vegas’ help file:
    The following attributes will be pasted:
    Event switches
    Audio event pitch shift
    Video event playback rate and undersample rate
    Video event effects and effect keyframes
    Video event pan/crop settings
    Video event velocity envelopes
    Edward Troxel
    JETDV Scripts
