Activity Forums Adobe Premiere Pro Pasting Effect Keyframe After Slipping Video
  • Pasting Effect Keyframe After Slipping Video
    Posted by Hirum Horkweller on June 9, 2015 at 5:50 am
    Hello Editors,
    Can anyone tell me if it is possible to paste keyframes for an effect to a clip after the clip has been slipped in the sequence?
    Specifically what I’m trying to do is this:
    I have a clip where every 5 frames the curve changes. I’ve got a sequence of keyframes that are all handmade RGB curves that I spent a lot of time on. Problem is I need to slip my edit and when I do my keyframes disappear. So in the effect editor I select the keyframes, right-click and choose “copy,” then slip my edit… but when I hit paste nothing happens. So I’ll create a new keyframe at the point that I want to paste the keyframes (my logic being maybe I need to have a keyframe down first in order to paste), but I still can’t paste the keyframes I selected.
    If I copy and paste a keyframe in the window without slipping the clip, it works just fine, but slipping the clip seems to lose copied keyframes.
    Is there a way around this??
    – H
    Hirum Horkweller replied 11 years, 3 months ago 2 Members · 3 Replies
  • Hirum Horkweller
    June 9, 2015 at 6:08 am
    FYI- I can’t paste keyframe onto any effect after slipping the video, at least using the normal copy/paste method. Please someone tell me there’s a way. How could something so basic be missing from Premiere?
    – H
  • Dennis Radeke
    June 9, 2015 at 11:09 am
    Don’t know for sure, but have you tried the master clip FX in this particular case?
    https://helpx.adobe.com/premiere-pro/using/master-clip-effects.html
    HTH,
    Dennis – Adobe guy
  • Hirum Horkweller
    June 9, 2015 at 6:29 pm
    Hey Dennis,
    Thank you! This actually solved my problem.
    I wasn’t pasting keyframes into the master clip. I didn’t actually know that CC had introduced that feature (I’m a recent FCP convert).
    Using the master clip I am able to copy and paste the keyframes to wherever I need them, so if I slip an edit in the timeline I have only to go back to the master clip and simply drag the keyframes to the new edit point.
    I find it a bit odd that you can’t just copy and past keyframes in edited clips after you’ve changed an edit, but hey as long as there’s a solution.
    Thanks again!
    – H
