Activity Forums Apple Final Cut Pro Paste video – bring back my audio
  • Paste video – bring back my audio
    Posted by Oren Hercz on November 13, 2012 at 12:32 pm
    Hi folks,
    Pretty basic question here. If I edit video only into the timeline. Is there any way to get back the audio later? This function is basically useless to me if you can’t because I often like to edit without audio on broll, but then bring back any sync sound when it comes time to do the mix.
    Otherwise, I’m stuck doing it the old-fashioned way.
    Oren
    Oren Hercz
    Editor, Post-Production Manager
    Journeyman Film Company
    http://www.journeymanfilm.com
    Jeremy Garchow replied 13 years, 9 months ago 4 Members · 5 Replies
  • Steve Connor
    November 13, 2012 at 12:55 pm
    Match frame and drop clip back on as in FCP7, or you could multi-select all your Broll clips in the browser and drop the audio to zero before you start the edit, then pull the levels back up as needed later, which is what I do.
    Steve Connor
    ‘It’s just my opinion, with an occasional fact thrown in for good measure”
  • Michael Garber
    November 13, 2012 at 4:30 pm
    I echo Steve’s post. Only addition is that, instead of dropping audio down, you can also turn it off in the audio info pane. Then turn it back on when ready to edit audio.
    Michael Garber
    5th Wall – a post production company
  • Jeremy Garchow
    November 13, 2012 at 6:30 pm
    With the clip in question selected, hit shift-f, shift-r as fast as you can hit the keys.
  • Steve Connor
    November 13, 2012 at 6:45 pm
    [Jeremy Garchow] “With the clip in question selected, hit shift-f, shift-r as fast as you can hit the keys.
    Magic!
    Steve Connor
  • Jeremy Garchow
    November 14, 2012 at 3:24 am
    [Steve Connor] “Magic!”
    You provided the perfect setup.
