Activity Forums Adobe After Effects Paste text from clipboard
  • Paste text from clipboard
    Posted by Tudor Baican on June 4, 2024 at 11:14 pm
    Hello Friends,
    I wand to paste some text from my clipboard through a script.
    I use pbpaste for that and it works fine.
    var pasteText = system.callSystem(“pbpaste”)
    But some character are not supported like ș or ş … and I get some question mark instead.
    Do you know a work around for that?
    Tudor Baican replied 2 years, 3 months ago 2 Members · 2 Replies
  • Walter Soyka
    June 5, 2024 at 1:01 am
    I think your problem is that your text uses Unicode encodings, but something somewhere between pbpaste, stdin, and ExtendScript is treating the string as ASCII.
    The best workaround I can think of is to explicitly tell pbpaste to use a Unicode encoding, dump it to a file, and explicitly read the file back in with a Unicode encoding.
    Sample code:
    // create a temporary file
    var tempFile = new File("~/TempUnicodeText-" + Date.now());
    // pbpaste uses the LANG environment variable to determine its encoding
    // we'll explicitly set it for a UTF-8 encoding, then dump the clipboard to a file
    system.callSystem("export LANG=en_US.UTF-8 && pbpaste > " + tempFile.fsName);
    // let's explictly decode our new file with UTF-8, read in the contents,
    // and then delete the temporary file
    tempFile.encoding = "UTF8";
    tempFile.open();
    var pasteText = tempFile.read();
    tempFile.close();
    tempFile.remove();
    // now pasteText holds our Unicode-encoded string,
    // and we can do whatever we want with it
    alert(pasteText);
  • Tudor Baican
    June 5, 2024 at 9:10 pm
    Walter, lot of thanks!! you saved me 🙂
    It’s a bit annoying that it doesn’t work by default but sometime small details are just laborious.
    I will implement your workaround and tell you.
    Thanks again!
