Activity Forums Adobe After Effects Paste reverses layer order
  • Paste reverses layer order
    Posted by Matthew Beall on June 14, 2013 at 3:18 pm
    I have noticed: if I select several layers in one comp and copy/paste them into another, the layer order is reversed.. Is there a way around this? It really screws up your track mattes.. 🙁
    Todd Kopriva replied 13 years, 2 months ago 3 Members · 3 Replies
  • John Cuevas
    June 14, 2013 at 4:07 pm
    Select your top layer, hold down shift and select the bottom layer, cntl+c, cntl+v will maintain the order. AE pastes in order of how you selected the layers. In a few quick tests if you hit Cntl+A, it works top to bottom also.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Matthew Beall
    June 14, 2013 at 4:19 pm
    Aha, you are correct..
    For whatever reason, I guess I was always selecting bottom up…!
    Thanks, that saves me lots of time re-ordering layers..! 🙂
  • Todd Kopriva
    June 16, 2013 at 3:25 am
    from After Effects Help:
    “When you copy (or cut) and paste layers, the layers are pasted so that they appear from top to bottom in the Timeline panel in the same order in which they were selected before the copy (or cut) operation. You can Ctrl-click (Windows) or Command-click (Mac OS) layers to select them in any arbitrary order, cut them, and then immediately paste them to reorder the layers in the order in which they were selected.”
    After Effects team blog
