Activity Forums Apple Final Cut Pro Paste Replace Effects in FCP X
  • Paste Replace Effects in FCP X
    Posted by Ryan Hughes on December 18, 2020 at 4:14 pm
    Is there a way to Paste Replace Effects in FCP X? Or any workarounds? I made a minor tweak to my keyer settings which will apply to dozens of clips. Would love the ability to replace the old settings with the new in one shot.
    Mark Smith replied 5 years, 8 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    December 18, 2020 at 4:22 pm
    It’s a multistep process. First, select the clip whose settings you like, and hit command-c (copy). Then select the clips you want to change, and hit shift-command-x (or Edit > Remove Attributes…) and then hold option and select the keyer effect. This will select ONLY the keyed effect that you want to remove. Then hit shift-command-v (or Edit > Paste Attributes) and option-choose the keyer effect again, which will paste ONLY the keyed effect. I’d suggest trying this on a subset or a duplicate set of clips (maybe copy/pasted at the end of the timeline, or in a Snapshot) first, before doing the whole timeline, just do you have a sense of how it works.
  • Mark Smith
    December 19, 2020 at 2:02 pm
    The time line index can be your friend here when selecting a bunch of clips scattered through a time line .
