Activity Forums Adobe After Effects Paste mask as motion path
  • Paste mask as motion path
    Posted by Thomas Gabrielsen on December 14, 2005 at 12:40 pm
    When I try to paste a mask as in to a layer as a motion path as described in the help file it will 99% of the time be pasted in as a mask. If I copy a path in Illustrator (or create a mask in After Effects without deselect it) and past it directly into the position property it works great, but otherwise it will be pasted as an additional mask. So now the solution has been to copy the mask from AE and paste it into Illustrator, then copy it in Illustrator and paste it into AE. I have absolutely no idea what I’m doing wrong. Can anybody explain what I do wrong, please?
    Thomas
    Thomas Gabrielsen replied 20 years, 9 months ago 2 Members · 2 Replies
  • John Cuevas
    December 14, 2005 at 3:16 pm
    Twirl down the mask properties, and instead of copying the “mask” copy “mask shape” Now you should be able to use that as your path.
    Johnny
  • Thomas Gabrielsen
    December 14, 2005 at 4:43 pm
    Thank you very much! 🙂
