Activity Forums Boris FX “Paste” keyframe values in BCC?
  • “Paste” keyframe values in BCC?
    Posted by Nate Whited on July 13, 2009 at 8:01 pm
    Using BCC 5.0 for Avid. I notice there is a function which allows you to copy all values at a particular keyframe…is there also a function that will allow you to paste those values at another keyframe? That would make sense, but I sure don’t see it….
    Peter Mcauley replied 17 years, 2 months ago 2 Members · 3 Replies
  • Peter Mcauley
    July 14, 2009 at 1:03 pm
    Hi Nate,
    You’ll need to add copy the keyframes that you need to duplicate, then create a new keyframe, select the new keyframe, and then paste the copied values by using the control+v keyboard command. One would think that there would be a menu item “paste copied keyframes” and if there is such a thing it’s something that I couldn’t find in the menu list.
    Hope that helps.
    Peter.
  • Nate Whited
    July 14, 2009 at 1:51 pm
    About an hour after I posted the above I just tried doing the paste off my keyboard and it works. It’s silly that isn’t an option from the mouse, but hey as long as it works–and it does. THANKS!
  • Peter Mcauley
    July 14, 2009 at 2:02 pm
    Hi Nate,
    Yes, I would also have expected that to have been in the list … unfortunately there’s nothing that we can do about that though as the list contents is set by the host.
    Cheers,
    Peter.
