Activity Forums Adobe After Effects Paste from Premiere Pro to after effects problem.
  • Paste from Premiere Pro to after effects problem.
    Posted by Paul Wright on March 4, 2012 at 8:55 pm
    Hi there,
    bit of a boggle here.
    When I copy and paste a sequence into after effects and try to ram preview it, I get the “need more than two frames message come up, even though I am in the middle of a clip. There’s obviously something I am doing wrong here, just wondering if anyone else has had this?
    Cheers in advance,
    Paul
    Paul Wright replied 14 years, 6 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    March 5, 2012 at 1:25 am
    Check the duration of your Work Area which is the area within the Timeline that AE defines for RAM Previews, by default.
    Occasionally, even if the Work Area is set to longer than a frame in length, the said error message may yet appear. A restart normally helps to sort things out.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Paul Wright
    March 5, 2012 at 8:58 am
    cheers for the reply. It’s fixed itself. I may have re-started, can’t remember.
    But it’s all hunky dory now.
