Activity › Forums › Blackmagic Design › passing/editing VANC with Decklink Studio
  • passing/editing VANC with Decklink Studio
    Posted by Adam Szabo on October 19, 2010 at 7:09 am
    I started a project with Decklink Studio. My final goal is to insert some VANC data into SDI stream.
    First tests showed that if I use Composite input and output with Media Express, TXT information (PAL signal, lines 20-22) is not going trough against all my efforts. I specified the lines I want to preserve in Control Panel, but nothing comes out. I tried to convert the Composite signal to SDI with Broadcast Converter, but the result was the same.
    Is there a way to pass this information? What am I missing?
    If I develop my own application, will it work on all the interfaces or just SDI?
    If I loop through SDI data, can I edit it on the fly with only one card?
    Thanks in advance.
    Adam Szabo replied 15 years, 11 months ago 1 Member · 1 Reply
  • Adam Szabo
    October 23, 2010 at 9:58 am
    Sorry. My bad. Dumm questions. I figured it out.
