Activity Forums Apple Motion Pass Through, Normal et al within a composition
  • Pass Through, Normal et al within a composition
    Posted by Lawrence Eaton on April 2, 2016 at 7:18 pm
    I took it upon myself to break up a project to manageable “lumps”, with the thought that I could simply drag and drop them to build the final version.
    It’s all worked rather well, except one part.
    When I drag and drop each component project into a “Master” project I seem to have “Pass Through” as the default blend mode. I’ve tried changing this to normal at the “Group” level or at the individual level but I still seem to have a semi transparent graphic element, no matter which one I use.
    Is this WAD, or maybe I’ve missed something? Can anyone help, please ?
    Lawrence
    Bret Williams replied 10 years, 5 months ago 2 Members · 1 Reply
  • Bret Williams
    April 8, 2016 at 1:56 pm
    Blend mode and transparency are two different things. So if you have transparent items in your group, they need to be adjusted within the group itself.
