Activity Forums Adobe After Effects Pass Through in After Effects for blending modes?
  • Pass Through in After Effects for blending modes?
    Posted by Travistevens on October 20, 2005 at 9:51 pm
    Hey guys this is my first post, i know what took me so long.. Anyway I’ve been using AE and photoshop for quite a bit of time and this is first time i’ve ever needed to do this so here goes.
    In photoshop you cna group layers that have different blending modes and then in the main group you have the option to select “Pass Through” in the blending mode options so that all the blending modes in the group will effect the rest of the document regularly. Well, in AE i have a Pre Comp with one 2 layers. One (the bottom) is Linear Dodge and the second (top) is Luminosity. When i place the precomp in my main time line the color dodge dosn’t work as it should, it meerly shows up as a regular layer with no blending mode.
    Obviously what i need is to figure out how to have different blending modes in a precomp effect everything beneath it in the main time line. Thanks so much for any and all help
    Travis Stevens
    Sam Palmer replied 9 years, 11 months ago 8 Members · 9 Replies
  • 9 Replies
  • John Dickinson
    October 20, 2005 at 11:54 pm
    Click on the “Collapse Transformations” switch for the precomp layer which looks like a little black sun. This will give you what you’re after.
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Travistevens
    October 21, 2005 at 2:50 am
    Thanks for your response but i’m not having any luck with that. It’s still not letting the “color dodge” layer in my precomp blend with the rest of the timeline.
  • John Dickinson
    October 21, 2005 at 6:11 am
    hmmm, can you take a screen shot and give us a look?
    JD
    John Dickinson
    Motionworks
  • Brad Strickman
    June 7, 2010 at 12:39 am
    5 years later, and multiple versions later this is still an unresolved issue. I don’t think enough people encounter this issue for Adobe to solve it, but when you hit it, it is really frustrating.
  • Nathaniel Schweinberg
    November 27, 2010 at 2:09 am
    It’s working for me… CS4
  • Will Eccleston
    January 5, 2012 at 10:17 pm
    It has never worked for me, on CS 3,4,5, and 5.5 on the Mac. And yeah, it’s super-annoying.
    Will Eccleston
    Kinetiscape Films
  • Bryan Batcher
    December 18, 2015 at 11:01 pm
    Click the little sun thingy. Worked for me.
  • Darby Edelen
    December 20, 2015 at 5:38 am
    If you add any effects or layer styles to the pre-comp that has collapse transformations enabled then it will break the “pass-through” of the blend modes. The blending mode of the pre-comp should be “-” as in the image Bryan posted, if it’s anything else (e.g. “Normal” or “Add”) then the blend modes inside the pre-comp are not being used.
    Darby Edelen
  • Sam Palmer
    September 20, 2016 at 9:54 am
    OK, I think I found out what the problem is having ran into the same problem dozens of times myself.
    It’s not actually the ‘pass through’ that’s the problem, as everyone has said, the little star/sun icon does that.
    What I suspect the problem is, is that the group in photoshop basiaclly has a mask on it which isn’t translated to AE when it’s brought across. You can see if this is true by opening the file in photoshop, putting a white solid at the top within the group that’s being problematic, then dropping a black solid underneath this group.
    What you should get is an image like this:
    You can then save it as a tiff (no need for layers) and then use it as a Luma Matte for all the items within that group.
    Hope that helps!
