Activity Forums Maxon Cinema 4D Pass through dynamics with boole
  • Pass through dynamics with boole
    Posted by Mike Carrier on June 13, 2011 at 6:33 pm
    I’m kinda new to c4d. using AE regularly I wanted to learn more 3d. Figured cinema 4d was the option. I am trying to recreate a marble trap using dynamics with out any keyframes. I am having an issue trying to get the marble to roll through a hole created with boole. It’s as if the hole was never made. Any one have another way to make a cylinder shaped hole through a tube to allow a ball to roll through?? maybe my dynamic settings are wrong??
    Mike Carrier replied 15 years, 3 months ago 2 Members · 2 Replies
  • Brian Jones
    June 13, 2011 at 7:50 pm
    the Dynamics tag on the Boole should have Collision/Shape set to Static Mesh (or Moving Mesh if the boole is animated)
  • Mike Carrier
    June 14, 2011 at 3:04 am
    Thanks the problem was I had the dynamic tag on one of the boole’s childs and it must not work at all that way. Fixed the issue when I removed it.
