Activity › Forums › Apple Final Cut Pro Legacy › Partly brightness adjustment?
Posted by Christian Friis on January 9, 2012 at 7:17 pmHi there,
For quite some time I have duplicated a video track, placed it on top of the existing video track, and made a feathered “hole” in the top track (by adding a garbage matte), which allows me to adjust brightness/contrast/saturation etc independently in the 2 tracks. Makes sense? Ie if I want to raise the light, brightness on a talking head, but keep the background at the recorded level, this would be the way for me to do it. But I keep thinking, that there must be an easier alternative to this “selective adjustment”…? Any feature that I’ve missed?Thank you very much,
Christian.
Bret Williams replied 14 years, 8 months ago 4 Members · 7 Replies -
Shane Ross
January 9, 2012 at 7:26 pmColorista2 by redgiantsoftware.com is a color correction plugin that is far superior to what FCP offers, and it has SECONDARIES that allows you to VIGNETTE are area of your choosing, and make adjustments only to that area.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Christian Friis
January 9, 2012 at 7:59 pmHello guys,
Thank you very much for your input. I appreciate that.
I’ve just watched the colorista2 highlights video – seems that this will solve the “problem” – at least making work progress (and probably end result!) better and more smooth!
All the best,
Christian. -
David Roth weiss
January 9, 2012 at 8:01 pm[Shane Ross] “Colorista2 by redgiantsoftware.com is a color correction plugin that is far superior to what FCP offers, and it has SECONDARIES that allows you to VIGNETTE are area of your choosing, and make adjustments only to that area.”
And, Apple Color also has the same capability.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comDon’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1POST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Shane Ross
January 9, 2012 at 8:10 pm[David Roth Weiss] “And, Apple Color also has the same capability.”
But Colorista 2 allows you to stay in FCP, instead of sending it to another app.
Shane
Little Frog Post
David Roth weiss
January 9, 2012 at 8:15 pm[Shane Ross] “But Colorista 2 allows you to stay in FCP, instead of sending it to another app.”
True! However, Color is free, and Colorista 2 is “rather” expensive.
David Roth Weiss
Los Angeles
Shane Ross
January 9, 2012 at 8:41 pm -
Bret Williams
January 9, 2012 at 9:35 pmThe 3 way color corrector should be able to do this just fine. It really is powerful once you learn how to use it. Once you’ve created a matte with it for the area you want to correct, duplicate the effect and invert the matte on the second instance and you can adjust the rest of the image. And of course you won’t have to keyframe the mattes since its based on chroma and luma like a color key and will follow the image. Only time you need a garbage matte is if two areas are too similar to be adjusted separately, but that’s going to be the case with any tools.
