Activity › Forums › Apple OS X › Partitioning Advice
Partitioning Advice
Posted by Andy Lancaster on December 31, 2007 at 5:42 pmI have Dual 2.566 GHz Mac Pro. I bought a 750g internal SATA drive. Should I partition it?
Chris Mackenzie replied 18 years, 8 months ago 3 Members · 4 Replies -
Zane Barker
January 1, 2008 at 12:33 am[Andy Lancaster] “Should I partition it?”
Why not just add additional drives?
Why would you want to partition it? I don’t see any potential advantages to it.Happy Editing To You!!
Chris Mackenzie
January 1, 2008 at 7:10 pmYou might want to partition it if you want to put an emergency boot on there, or a place to play/test different systems (~20GB). The only other reason I can think of is for backups. If you are running 10.5 you could setup a time machine backup that is constrained to a certain size. If the drive is just for additional storage I’d leave it as one partition.
Aloha,
-Chris
Zane Barker
January 2, 2008 at 6:14 am[Chris Mackenzie] “The only other reason I can think of is for backups”
Its not a real back up if it just on another partition on the same hard drive. If the drive dies then your originals and your backup is gone. You want backups on a completely separate drive.
Chris Mackenzie
January 2, 2008 at 6:37 amYes, very good point.
I meant for a backup of the other drive, not what is on the new drive.
Aloha,
-Chris
