Activity Forums Adobe After Effects Particular Wrap Around
  • Particular Wrap Around
    Posted by Raine Vivian on September 2, 2010 at 12:30 am
    Hey guys,
    So I’m trying figure out a way to do this but cant seem to find a good way to do so.
    I’m trying to get a particle effect (from particular) to wrap around another layer in 3d space, so it goes in front and behind it (leaving behind particles as well).
    I have watched Aharon Rabinowitz’s Better Compositing with Partials, but this is not the answer I’m looking for, due to the camera movement. I don’t know. Any idea’s? Thanks guys!
    -Raine Vivian
    http://www.rainevivian.net
    http://www.seaboundesign.com
    Raine Vivian replied 16 years ago 4 Members · 5 Replies
  • Justin Gray
    September 2, 2010 at 12:46 am
    Can you apply it to a 3D motion path?
    Thanks Fellow Bovines,
    Justin Gray
    Senior Editor/Motion Graphics Artist
    Encore Multimedia
    web.me.com/grayplanet
  • Tudor “ted” jelescu
    September 2, 2010 at 9:56 am
    There’s a forum on the Cow for that- best get your answers there.
    https://forums.creativecow.net/trapcode
    That being said, Make sure you apply Particular to your top 2d layer, always keep that on top, and enable obscuration layer- Particular will read the 3d info of all layers below.
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
    Bucharest, Romania
  • Galen Young
    September 2, 2010 at 4:53 pm
    There’s a nice AE script from Sébastien Périer on aescripts.com called sParticular that helps Particular interact with other 3D layers. Check out the two short video tutorials (one is in the comments) to see if it will do what you need.
  • Raine Vivian
    September 2, 2010 at 6:50 pm
    Thanks guys, let me look in to it, and I’ll get back to you in a sec. Again thank you.
    -Raine Vivian
  • Raine Vivian
    September 2, 2010 at 7:28 pm
    So I downloaded the sParticular script, but it dose not seem to work with the Aux particals that trail behind the Emitter. Not really sure where to go from here.
    -Raine Vivian
