Activity Forums Adobe After Effects Particular won’t follow exact path
  • Particular won’t follow exact path
    Posted by Matthias Mang on August 14, 2017 at 7:28 am
    Hi everybody.
    Trapcode Particular is driving me crazy.
    I’m trying to get the Emitter to follow a path which has been created through a Null – Object. Everything works fine, it follows. BUT: not the exact path, meaning it always a good bit next to it. Realigning it (anchor point e.g.) doesn’t fix the problem.
    The idea is to highlight a certain line in a video, but if it’s not exactly moving on in, it’s not really worth using it.
    I’m using AE CC and Particular 3.0
    I’m thankful for any help I can get!
    Daniel Hetherington replied 9 years ago 2 Members · 1 Reply
  • Daniel Hetherington
    August 15, 2017 at 1:27 pm
    I don’t have Trapcode in front of me, but I believe you have to change the emitter sub frame to something like “10x Linear”. This option is under Emitter on your particular layer.
