Activity Forums Adobe After Effects Particular with Depth of Field
  • Particular with Depth of Field
    Posted by John Hammond on July 15, 2009 at 3:03 pm
    Is there a standard way to get my ‘3d’ cloud of trapcode particular particles to have depth of field?
    I want it to be a real, live depth of field so as I rotate the particle cloud, individual particles come in and out of focus.
    John
    Lee Skinner replied 17 years, 1 month ago 3 Members · 3 Replies
  • Riccardo Sinti
    July 15, 2009 at 3:07 pm
    Add a camera and turn it’s depth of field on. And in particular chose a particle that supports DOF and select Full Render + DOF in the last tab that says Render Mode
    Thank You
  • John Hammond
    July 15, 2009 at 3:17 pm
    Ah, thanks! so simple.. for some reason I assumed I would need to ‘switch it on’ within particular.
    thanks
    John
  • Lee Skinner
    July 15, 2009 at 4:33 pm
    Although, I believe only the most recent version of Particular has this capability. For the longest time, I had to make due with a version that could not let particles be affected by depth of field… X(
    _________________________________________________
    [Design is what you leave out.]
