Activity Forums Adobe After Effects Particular Transition for film. Need Advice please
  • Particular Transition for film. Need Advice please
    Posted by Josh Brine on April 25, 2012 at 7:54 pm
    Hi all,
    So im working for a client, who decided that he would like a shot of a character appearing from ‘dust’ & ‘particles’
    I have Form & Particular, so im using them as my basis for this effect.
    now, im not an experienced compositor,
    I dont know what i need to add to really make this effect look good. it also has quite a few limitations,
    the transition can only be a few seconds long, due to the acting.
    the shot is very flat. there is very little zdepth and currently if i just use particular it looks very ‘motion graphic’ and not very intergrated into the shot.
    Here is what i have so far,
    1. Separated the character from the background with Mocha,
    2. Took several stills and pieced together a clean plate. which i tracked into place.
    3. Am using the layer of just the talent as a layer emmitter for my particular, which is a great effect, as it looks like he is dissintergrating.
    4. have began messing with the properties of particular.
    Here are some problems/difficulties/challenges.
    1. The shot is very flat, for me this effect so far lacks any kind of intergration & connection with the shot.
    2. the short time of the transition makes it hard to find a good effect that will look good.
    So,
    Can i please get some advice, on techniques, things to look out for, how to add depth and realism to a shot, what layers i need to think about when trying to add a good level of integration.
    Josh
    Josh Brine replied 14 years, 4 months ago 2 Members · 2 Replies
  • Benjamin Ausmith
    April 25, 2012 at 8:46 pm
    Add some camera shake! Hides your mistakes and makes it seem like it’s adding a greater level of complexity than it actually is.
    Benjamin Ausmith
    Post-Production Assistant
    Monadnock Media, inc.
  • Josh Brine
    April 25, 2012 at 9:14 pm
    THanks, ill do that.
    Shall i just punch in 10% then add some wiggle to a 3d camera?
    thanks for responding.
