Activity Forums Adobe After Effects Particular Size/Opacity Over Life
  • Particular Size/Opacity Over Life
    Posted by Scott Smith on May 3, 2016 at 1:14 pm
    Particular size and opacity over life is not responding I’m using adobe after effects cc 2015.
    Even using default particular effect with the only thing changed being the size/opacity over life it still isn’t responding.
    setup is as follows, new solid>add particular>size over life (decaying). this has no effect. However,If i save the file and open in 2014 the effect works as its meant to.
    I revert back to cc 2014 at them moment but would appreciate suggestions regarding what could be causing the bug.
    Thanks in advance
    Scott
    Walter Soyka replied 10 years, 4 months ago 2 Members · 1 Reply
  • Walter Soyka
    May 3, 2016 at 1:47 pm
    Make sure you’re up-to-date on Particular. You must be on at least Particular 2.2.5 for compatibility with Ae CC 2015.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
