Activity Forums Adobe After Effects particular shading | specular and reflection maps
  • particular shading | specular and reflection maps
    Posted by Manojit Ghose on July 15, 2010 at 3:14 pm
    in my comp i am apparently unable to make the “specular” and “reflection map” features enabled.
    i tried including point/spot lights in the comp, still those fields are grayed out.
    changing the “light falloff” also didn’t help.
    i have looked into the help section… nothing mentioned specifically about enabling those features. in the help only the attributes and their functions are explained.
    does anyone have any clue what i might be doing wrong??
    MG
    Manojit Ghose replied 16 years, 2 months ago 2 Members · 4 Replies
  • Manojit Ghose
    July 15, 2010 at 7:03 pm
    thanks for taking time to read the post.
    its particular 2.0 and AE CS4. and i agree i should have mentioned it in my post.
    manojit
  • Manojit Ghose
    July 15, 2010 at 9:52 pm
    i agree that those two settings are different from the help settings. but i tried same settings as well…however they didn’t work as well..its just that i took the screenshot they had diff settings.
    and yes the help i referred is for the same version i am using.
    manojit
    PS: in the help settings even though the “shadowlet for main” is “off” the “shadowlet settings” are not grayed out!
    MG
  • Darby Edelen
    July 17, 2010 at 12:38 am
    The specular and reflection map properties are only available if you’re using one of the ‘Textured Polygon’ particle types.
    Darby Edelen
  • Manojit Ghose
    July 17, 2010 at 2:45 pm
    hi thanks,
    my earlier composition was not working using textured polygons however when i started from scratch it seemd to work just fine!
    but many thanks for your tip.
    cheers
    manojit
