Activity Forums Video Copilot particular ring
  • particular ring
    Posted by David Maloney on April 8, 2008 at 2:07 am
    In Andrew Kramers last tutorial He gave us an expression (Preset 3d orbit) that makes particular form a ring. Pretty cool I say.no need for motion path. What would one have to do to make the ring stand up like an O with out use of a camera position and position it anywhere in the frame not just the center. any thoughts? FYI working on a project where after two or three revolution my O turns into an arrow and shoot up a graph. Any thing will be helpful. I know I probably have to make a motion path. Wanted to know if there was anyway to tweak the expression. if not sure what I am talking about check out his last totorial on videocopilot.com
    David
    David Maloney replied 18 years, 5 months ago 2 Members · 2 Replies
  • Darby Edelen
    April 8, 2008 at 7:15 am
    I’m not sure what the whole set up was, but the basic expression for a circle is:
    angle = degreesToRadians(45);
    x = Math.cos(Math.PI * 2 * angle);
    y = Math.sin(Math.PI * 2 * angle);
    [x,y]
    Andrew probably adapted the 2D circle into other dimensions. For example, changing the last line to:
    [x,y,0]
    Would give you a constant Z value of 0, so the circle would lie on the XY plane.
    [x,0,y]
    Would give you a constant Y value of 0, so the circle would lie on the XZ plane.
    However, I think an easier solution would be to parent the emitter (if its a light or a null object) to a Null object and rotate that around whatever axis you want. If you’re using a null object then this would require the expression applied to the Particular emitter expression to be improved. For the X & Y coordinates:
    l = thisComp.layer("Emitter");
    x = l.toWorld(l.anchorPoint)[0];
    y = l.toWorld(l.anchorPoint)[1];
    [x,y]
    And for the Z coordinate:
    l.toWorld(l.anchorPoint)[2];
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • David Maloney
    April 8, 2008 at 5:03 pm
    Cool. Thanks so much! expression are great, just need to get my head around them
    big help
