Activity › Forums › Adobe After Effects › Particular – “rain”drops – with stroke?
  • Particular – “rain”drops – with stroke?
    Posted by Bas V breugel on September 12, 2011 at 1:09 pm
    Hi guys,
    I’m animating some weather icons. So far so good, but now I’am struggeling with rain.
    I want to get this look:
    So i started with Particular. I got drops falling down with gravity… but how to make those ‘tail’ strokes? So the drop falls and leaves a trail behind it, wich fades.
    thnx
    Michael Szalapski replied 15 years ago 4 Members · 5 Replies
  • Michael Szalapski
    September 12, 2011 at 2:02 pm
    Two options:
    Motion blur
    Aux system
    In your case, I think the aux system would be your best bet. Read the documentation for Particular for an explanation for how to use it.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Ben G unguren
    September 12, 2011 at 3:22 pm
    Another (older-school) option is to use an adjustment layer over your particular and apply the Echo filter, Normal mode, with a fade value of around 90%
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Justin Parker
    September 12, 2011 at 10:59 pm
    lowering the shutter speed of the motion blur can also give the rain drops more of a tail.
  • Bas V breugel
    September 13, 2011 at 1:56 pm
    I went for the Aux option. Works like a charm, only there is no (good looking) size over life option. Wich means the stroke doesnt dissapear as nice.
    I worked arround that with making the particular layer a precomp and working with a feather mask.
    Thanks for the tips!
  • Michael Szalapski
    September 13, 2011 at 6:06 pm
    You can draw your own size over life graph just click and drag on the graph area. Don’t forget to click on the smooth button a couple of times after you draw it.
    – The Great Szalam
