Activity Forums Adobe After Effects Particular Question
  • Particular Question
    Posted by Max Jackson on September 13, 2012 at 2:41 am
    Hi, sorry if this is the wrong forum, but I am using After Effects.
    I have this particle stream where it’s pouring out like salt. I’m looking for two things to happen that I can’t seem to alter.
    1) I would like the particles to kind of curl up and whisk away like smoke and dust does with enough interference. I can use turbulence but it just seems to bend and twist the stream out of shape. I’m looking for random particles to curl up and disappear. Almost like an upside-down fountain.
    2) In the scene these particles must hit a floor and curl up at a certain x-point, much more severe than merely pealing off. In addition to 1) I need them to react to a surface and float upward like dry ice.
    If anybody has run into this before and can help point me in the right direction I’d appreciate it.
    Thanks for reading 🙂
    Max Jackson replied 14 years ago 2 Members · 2 Replies
