Activity › Forums › Adobe After Effects › Particular – now I can’t animate it’s rotation!
  • Particular – now I can’t animate it’s rotation!
    Posted by John Hammond on July 15, 2009 at 3:50 pm
    Hi there.
    I have a cloud of particles made using particular, and a camera with depth of field.
    When I spin the particle cloud on one of it’s axis (within the particular/emitter parameters) I can see it spinning in front of me, 75% of the time.
    When I make some keyframes and then play it back, there is no rotation… Tried playing with a few settings like emitter size (I’m using grid type) but I can’t make it work. I’ve made this work before with no problem. The only thing I’m doing different is using D.O.F camera.
    any ideas??
    John
    John Hammond replied 17 years, 2 months ago 3 Members · 3 Replies
  • Kevin Camp
    July 15, 2009 at 3:55 pm
    are you spinning the emitter or the camera…?
    for what i think you want, you’ll want to be rotating the camera around the cloud, rather than rotating the emitter as it is emitting…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Derek Hader
    July 15, 2009 at 4:23 pm
    I agree with Kevin. And I would also add that you should try to parent your camera to a 3D Null, place the 3D Null in the same (or near) XYZ position as your Particlar layer, and then animate the Null’s rotation values. This makes for much easier method of orbiting the camera around any point than trying to do it using a combination of the camera’s position and rotation/orientation values.
    Good Luck,
    -Derek Hader
    Oh Boy Productions
  • John Hammond
    July 16, 2009 at 10:25 am
    Hi, thanks to you both.
    Yes – I was rotating the emitter, not the cloud.
    John
