Activity Forums Adobe After Effects particular not following pasted illustrator masks
  • particular not following pasted illustrator masks
    Posted by Heather Crank on August 13, 2011 at 3:29 am
    Hello Everyone,
    I have an illustrator logo with outlined font that I would like to reveal with a particular light streak in AE. When I copy the path from illustrator into the position property of the particular emitter nothing happens. I can paste the mask from the font into the position property of a solid. I must be missing a step. Anyone know what I’m doing incorrectly?
    H
    Michael Szalapski replied 15 years, 1 month ago 3 Members · 5 Replies
  • Brian Charles
    August 13, 2011 at 9:54 pm
    When you paste the path to the emitter do you see Roving Keyframes?
    Is your path too small to register? Turn Directional Spread and Velocity Distrubution to 0.
  • Heather Crank
    August 13, 2011 at 10:59 pm
    Duh,
    Did something really dumb, was clicking on the mask layer instead of twirling down the mask and copying from the mask “position”.
    You don’t happen to know how to keep a light emitter from affecting other elements in the comp do you?
    H
  • Brian Charles
    August 14, 2011 at 12:28 am
    You can set the light intensity to 0 and in Particular change the Particles/sec modifier from Light Intensity to None, then use the regular Particles/sec property under Emitter.
  • Heather Crank
    August 14, 2011 at 12:35 am
    Thanks Brian!
  • Michael Szalapski
    August 14, 2011 at 1:07 am
    Turn off the eyeball on it.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
