Activity Forums Adobe After Effects particular line has some gaps
  • particular line has some gaps
    Posted by Ronny Traufeller on June 12, 2015 at 10:07 pm
    chers my friends
    i want to emit musical note lines,
    unfortunatly i have gaps between the points,
    so it does not perfectly form a line.
    i use a layer emitter pumping out from 6 dots in a row,
    seeems like the gaps are there because of my 25 framerate,
    witch seems to low for my emitter speed.
    somebody tried before?
    traufeller.de
    Ronny Traufeller replied 11 years, 3 months ago 2 Members · 3 Replies
  • Ronny Traufeller
    June 13, 2015 at 11:49 am
    i tried that to inhuman values,
    but it seems like i just get more particles in the
    dotted spots, the gaps still remain.
    so the structure of the dashed line becomes more clear when i
    increase the particles per second.
    my feeling is, that i need to emit even between the frames.
    R
    traufeller.de
  • Matthew Keane
    June 15, 2015 at 1:38 pm
    If your emitter is moving really fast and cranking up the particle count still leaves you with gaps, you might need to look at the ‘Position Subframe’ options in the Emitter settings and try setting it to ’10x linear’ or ’10x smooth’ to see if things work better. When the Emitter is moving very fast along a wiggly path, it can sometimes skip a section of the path altogether, which leaves gaps.
    Matthew Keane
    Freelancer based in Paris, France
    – Motion Graphics, Video Editing & Effects, Watchout Programming & Live Operation.
  • Ronny Traufeller
    June 15, 2015 at 2:29 pm
    thanks alot,
    i have a good feeling that this is what i am looking for,
    infortunatly its not available when using layer emitters.
    maybe i go for a point emitter and clone this setup 6 times
    fot the final thing.
    thanks,
    Ronny
    traufeller.de
