Activity Forums Video Copilot Particular – light streaks effect and motion captured path
  • Particular – light streaks effect and motion captured path
    Posted by Andreas Alm on September 29, 2008 at 10:00 pm
    I am having problems using Particular. (Based on https://www.videocopilot.net/tutorials/light_streaks/)
    I am using a motion captured path linked to a null to emit the laght streaks. However, the light-streak is not displaying correctly. Instread of beeing one smooth line (following the position of the motion tracker) I clearly see the particle shape..
    Sorry for my bad explanation, but I really dunno how to else describe it. I have tried differen emitter/particle settings.
    The only way to get the line”smooth” is if I delete the tracker path and set manual keyframes with longer distance between them. However, I need to use motion tracking. If i use “rove across time” the line is also smooth, but the drawing of it is …you guessed it: not on time…
    Any help is so much appreciated.
    Andreas
    Andreas Alm replied 17 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
